meddle636 Posted May 20, 2011 Report Share Posted May 20, 2011 I just got a new set of tm28 for my banshee. Looking for a good starting point and a little advice tuning them. I generally run at sea level or 1000 ft. My bike has stock bore prolite pistons and modsquad intakes and read cages fmf fatty pipes k&n filter vented stock box lid. I have changed a few things in them already. 280 main 15 pilot(by the main?) 175 needle jet 5li needle 1.5 bowl jet 32.5 pilot jet (back of the carb) Also is any lighter springs for the slides or do you just clip them shorter? Quote Link to comment Share on other sites More sharing options...
shakar Posted May 21, 2011 Report Share Posted May 21, 2011 you have to change them up abit try a search.....there was a some good info awhile back goodluck Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted May 21, 2011 Report Share Posted May 21, 2011 You need to post your nozzle size (the thing that said 175 on it) P4, P8? Your main jet may be too small. You pilot jet is too small. Should be at least a 20-25. Quote Link to comment Share on other sites More sharing options...
meddle636 Posted May 23, 2011 Author Report Share Posted May 23, 2011 the needle is a 175 p8 Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted May 24, 2011 Report Share Posted May 24, 2011 the needle is a 175 p8 it needs to be a p4 Quote Link to comment Share on other sites More sharing options...
meddle636 Posted May 24, 2011 Author Report Share Posted May 24, 2011 I'm guessing the p8 will be too rich in the mid range. Also do I need to change the slow jets in the bowl and or the one at the back of the carbs? Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted May 25, 2011 Report Share Posted May 25, 2011 I'm guessing the p8 will be too rich in the mid range. Also do I need to change the slow jets in the bowl and or the one at the back of the carbs? Slowjet? Are you talking about the pilot jet? Quote Link to comment Share on other sites More sharing options...
armyvet Posted May 28, 2011 Report Share Posted May 28, 2011 should have got a set of pwk keihins...easier to tune imo.but if the price was right cant blame ya. Quote Link to comment Share on other sites More sharing options...
shakar Posted May 29, 2011 Report Share Posted May 29, 2011 i was giving this info and it helped alot when i first set my carbs up slides 2.5 - needle jet 5L1 in the middle clip - jet needle 175 [p4] - flot height 22mm - needle seat valve 2.5 - pilot 27 1/2 - air screw 1 1/2 turns out Quote Link to comment Share on other sites More sharing options...
