I looked thru 37,000 pages on here using the search and it hasnt really helped all that much can someone please get me close.
1) What type of aftermarket exhaust do you have? R-2s
2) What type of airfilter do you have? K&N pods
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all. No airbox at all
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) Sea level-300ft ASL
5) What size pilot jets are you using? Currently a 58
6) What size main jets are you using? Currently a 165
7) What temperature is your Banshee jetted for? 70-80
8) Do you have a port job? Yes, Rudy Kurtz Dune Port
9) What kind of carbs? Keihin PJs
10) What size carbs? 34mm
11) Compression is 155 running 50/50 mix at 55to1
12) Stock reeds and cages
On my 4mm aggressive dune port motor with cpis I was running 162 mains and 50 pilots with CEL needles in the middle. It ran very well but was rich. Probably should have been 48 pilots and 158 -160 mains, but i didnt keep the 34pjs on too long so never fine tuned them. Like said earlier, drop the pilot and then go from there
