nastyracing Posted April 26, 2011 Report Posted April 26, 2011 I'm having so much trouble jetting my pwks one pipe has always been hot other cold to touch. Resync the carbs they were off a bit... But when did that it made the one pipe that was always hot even hotter n the other pipe is still cold. Even the exhaust coming out the tail pipes is the same one boiling hot other cold. No matter wht I do can't change this any ideas. There is no air leaks ect. My leftside hot cylinder the jetting is almost perfect. The right cylinder always reads rich when set up the same way. Wtf I've tried everything... Quote
Coupelx Posted April 26, 2011 Report Posted April 26, 2011 sounds like you need to look at your ignition system? Quote
muggzy Posted April 26, 2011 Report Posted April 26, 2011 I'm having so much trouble jetting my pwks one pipe has always been hot other cold to touch. Resync the carbs they were off a bit... But when did that it made the one pipe that was always hot even hotter n the other pipe is still cold. Even the exhaust coming out the tail pipes is the same one boiling hot other cold. No matter wht I do can't change this any ideas. There is no air leaks ect. My leftside hot cylinder the jetting is almost perfect. The right cylinder always reads rich when set up the same way. Wtf I've tried everything... swap plug wires and see if the problem moves. Jetting doesn't mean jack if you're running on one cylinder. I had a similar prob when I rebuilt my engine and my pilots and needles were lean. Quote
nastyracing Posted April 27, 2011 Author Report Posted April 27, 2011 Swapped plug boots same outcome swapped idle screws around also as one is slightly bent and causes to idle higher. Right pipe did warm up a bit left stayed the same I maybe tripping... Cylinders r even temps tho. Both cylinders have even spark tested that also. Gonna run bike as is left cylinder reading slightly leaner then rich right side just dialing air screws accordingly. Every test everything I tried changing has been negative so time to test it out in the sand. Quote
nastyracing Posted April 27, 2011 Author Report Posted April 27, 2011 Would float height have anything to do with one side being colder and richer then the other hot left side where the jetting looks dead on? Also does anybody have the float height specs? Quote
T_Shee Posted April 27, 2011 Report Posted April 27, 2011 ya float height could definitely affect it. pretty sure its 16mm on those. if it helps any i had the same problem with my 28's. didnt seem to matter what i did i couldnt get them to sync up right at lower rpm. finally fixed them by trading for some 35s. i no you said you checked for air leaks but i woiuld make sure the carb tops are sealed up good also. Quote
nastyracing Posted April 28, 2011 Author Report Posted April 28, 2011 I GOT IT !!!! SHEE is alive!!!! One the float heights were off set them all to SPEC. SYncd the carbs up yesterday they were off a bit. But its a rocket ship now bike jumps when u let the clutch out n the jetting I set up to 48 pilot 150 mains r dead on LRD needles in fourth position. Ready to tear some people up this weekend. Thanks for all the advice tips n knowledge ... Love this site. Quote
SAVAGE420 Posted May 18, 2011 Report Posted May 18, 2011 i thought it was 19mm for 28pwks 19mm is Correct for 28-30 PWK 16mm for 33-39 PWK All PJ's are 16mm as well. Quote
sleeper06 Posted May 18, 2011 Report Posted May 18, 2011 19mm is Correct for 28-30 PWK 16mm for 33-39 PWK All PJ's are 16mm as well. 33s are also 19mm ,35-39 are 16mm Quote
