bansheeboi Posted April 23, 2011 Report Posted April 23, 2011 this is my problem the bike has a stock carrier stock swinger and stock length chain now the carrier is all the way back to were the bolt line straight up and down and the chain is still very slack very slack also this carrier has a very small sprocket on it im think i change back to stock the size of the sprocket will take slack and therefore forceing me to adjust the carrier fwd and then adjust chain tensioners if im wrong let me know will post some pic tomorrow http://m1226.photobucket.com/albumview/albums/bansheeboi95/Mobile http://m1226.photobucket.com/albumview/albums/bansheeboi95/Mobile Quote
Glamis321 Posted April 23, 2011 Report Posted April 23, 2011 either that or cut a couple links off the chain to make it shorter. Quote
thomas h. Posted April 23, 2011 Report Posted April 23, 2011 maybe time for a new chain? aslo larger front sprocket.....if you want too I checked mine last week and the rear steel sprocket was wore out .. Quote
bansheeboi Posted April 23, 2011 Author Report Posted April 23, 2011 maybe time for a new chain? aslo larger front sprocket.....if you want too I checked mine last week and the rear steel sprocket was wore out .. it is a brand new chain im going with bigger Quote
muggzy Posted April 23, 2011 Report Posted April 23, 2011 (edited) A bigger rear sprocket will increase bottom end power and decrease top end speed. If you wanna keep your characteristics the same, go up ~one tooth in the front for every three you add in the back. You oughta replace both sprockets when you put a new chain on anyway.<br><br> <br>it is a brand new chain im going with bigger<br> Edited April 23, 2011 by muggzy Quote
