bansheeboi Posted April 12, 2011 Report Posted April 12, 2011 guys i cant get my bolts out me stingers to repack them i have sprayed them still the bolts will not come out and they do come out but only so many times and then the bolts stop and is very hard to turn after that feels like the bolt is going to ring off any suggestion guys also how do you clean the old oil and dirt out the pipes got them painted but not i need to repack them help guys thanks Quote
AKheathen Posted April 12, 2011 Report Posted April 12, 2011 what's happening, is you have build-up on the back-side of the screws. you don't have the snap-ring in the end that can be removed? if you cannot get to the back and clean them good, just keep spraying with penitrant and working them in and out. cut them a little shorter before putting back in. worst case scinario, back tham out untill they are just not stuck, then cut the head and make a slit in them, then you can run them through the other way once you have it apart, or even grab with vise grips from the back and run them through. Quote
bansheeboi Posted April 13, 2011 Author Report Posted April 13, 2011 yea they dont have the ring on the end of them who ever had them before me took a flat head and tape the outter flip with slits in them to keep the back on but i will try that thanks bro Quote
