Banshee Rider239 Posted April 10, 2011 Report Posted April 10, 2011 ok this is a 1990 Mojave 250cc Carb (4 stroke) ....i went an picked up my brother Mujave and i kicked it the first time it crunk up and i drove it down the strreet but it feels like the speed is bein restricted so what i did i opened up the carb to make sure it was clean inside because it have been sitting in a garage for about a year...i notice the needle in the carb was missin the hole when it goes up in down so i took off the top part of the carb an i set the needle to go straight down in the hole instead of leaning a little an put the spring back in the position its suppose to be in then i put everything back together an i went to kick to crank it again it wouldnt crank i have here a few pics of what the carbs look like in the inside an pics of the needle missin the hole before i fixed it ...an the side of the carb has a few adjustments on the side like i see it has a stem in three places where does the gasline go correctly ? and what is the other stem near the gasline stem go to ? because the overflow is at the very bottom of the carb ....the problem i had earlier after i put the carb back together was trying to give it a spin was everytime i turned the gas on all of the gas came straight out of the overflow i got it to stop somehow when i opened up the carb but still cant crank its a adjustments that need to be made can you guys give me some help thanks Quote
Banshee Rider239 Posted April 10, 2011 Author Report Posted April 10, 2011 needle missing the hole before Quote
