Well when I got the shee I noticed the right pipe smoking a lot more than the left pipe. I had to rebuild it and after the rebuild the right pipe still smoked more. I also noticed that the right header gets hotter and faster than the left when I let it warm up. I swapped plug wires and still the same outcome.
It has a trinity 2 into 1, 38mm carb intake so I never fully understood why one pipe was smoking more than the other. At one point I let a friend run with my full exhaust and both pipes where smoking about the same on his. Any help with this would be appreciated!
well I finally made a pressure tester. I got it to exactly 6psi, after 2 minutes it was at 5.5psi and after 4 minutes it was just below 5psi, figured that was not too bad. I have decided to ditch the single carb set up and try a set of dual carbs, is it possible that the single carb is not feeding the cylinders evenly? I was going to sell or swap my single carb set up, but I don't want to sell any bogus parts.
I need some help on figuring it out. The local fair is in about a week and a half and they usualy have quad races, I want to be there but want my shee running right or not at all!
