ndaphne Posted February 15, 2011 Report Posted February 15, 2011 I have 94' Banshee with pro design cool head 16 cc domes, 65.5 mm pistons, SA answer pipes, electro- sport stator v-force 3 reads and a t 2 to 1 intake manifold. I would like to replace the carb as i do not know it's history and i think it is causing me problems. I'm having a hard time figuring out the prop size for my set up. any one have any thoughts they would like to add? Quote
Trick2stroke Posted February 15, 2011 Report Posted February 15, 2011 If you're asking for size recommendations people usually use a 35-39 mm carb from all I've seen and used. I have an extra 39mm lectron /w 14" K&N clamp on filter that would be perfect for a 2-1. Pm me if you're interested. Quote
Snopczynski Posted February 15, 2011 Report Posted February 15, 2011 I have 94' Banshee with pro design cool head 16 cc domes, 65.5 mm pistons, SA answer pipes, electro- sport stator v-force 3 reads and a t 2 to 1 intake manifold. I would like to replace the carb as i do not know it's history and i think it is causing me problems. I'm having a hard time figuring out the prop size for my set up. any one have any thoughts they would like to add? 35mm Quote
camatv Posted February 15, 2011 Report Posted February 15, 2011 can you post pics of the pipes.. Quote
armyvet Posted February 15, 2011 Report Posted February 15, 2011 i had the 35mm pwk on my single set up a couple yrs back.I remember running a cel needle and the eek needle as well trying to get it dialed in.48pilot and i think a 185 main or so.it ripped once its dialed in so hang in there! Quote
