bansheesrtoys Posted January 28, 2011 Report Posted January 28, 2011 ok well i had the bowls on backwards. and before i did it would idle up when i pulled the choke and idle back down when i pushed it in, and it was a pain in the ass to start.Now that i put the bowls on the right carbs it starts right up in one or two kick. But when i pull the choke now it doesn't idle up or change at all.i also went from a 300 main for summer to a 320 for winter. what could be wrong? and yes my carbs r clean Quote
bansheedude55 Posted January 28, 2011 Report Posted January 28, 2011 (edited) ok man... i had the same problem... you have to connect a tube in between the two carbs,,, just like the pic below... same shit wit mine too...it really fixes everything! Edited January 28, 2011 by bansheedude55 Quote
bansheedude55 Posted January 28, 2011 Report Posted January 28, 2011 let me know if thats it if not there could be other solutions but that should be it man! Quote
bansheesrtoys Posted January 28, 2011 Author Report Posted January 28, 2011 (edited) no thats not it. i have the tube hooked up. i was thinking it could be the choke plunger, but it worked befor i swithed the bowls over. could running the bowls on the wrong carbs mess up the choke when you put them back where they belong. I had them backwards for 4yrs, because thats how i bought it and didn't know any better. but then again it never started this good. Edited January 28, 2011 by bansheesrtoys Quote
banshee55 Posted January 29, 2011 Report Posted January 29, 2011 Well its not a bad thing... But maybe ths guy u bought it off sinked the floats upside down... You might have to go get the carbs sinked so the floats are right... If not when u pull them off play with the choke and see if the cartrege is openin and closing.... Quote
bansheesrtoys Posted January 29, 2011 Author Report Posted January 29, 2011 But maybe ths guy u bought it off sinked the floats upside down... You might have to go get the carbs sinked so the floats are right... what do you mean? i thought that the flaots only go on one way. is there a left and right float? or are they both the same? and as far as getting them sinked or" synhronizing" the carbs. i did it with the tool and its perfect Quote
banshee55 Posted January 30, 2011 Report Posted January 30, 2011 They do just make sure the carb syncs are evan and check you jetting also read the number on the sides of all 4 mains and make sure they match ur kind of intake or exaust.. Quote
bansheesrtoys Posted January 30, 2011 Author Report Posted January 30, 2011 They do just make sure the carb syncs are evan and check you jetting also read the number on the sides of all 4 mains and make sure they match ur kind of intake or exaust.. What ? Quote
bansheedude55 Posted January 30, 2011 Report Posted January 30, 2011 make sure the floats are set the same on both carbs.. and the jets in the carbs have numbers on them just make sure the 2 mains match eachother in the opposite carbs and do the same with the smaller jets... then let me know.. if you have aftermarket pipes and/ or filter box the jets need to match them... if u dont have the jets right it will never run right and u gotta get that done by a specialist or yamaha stealership..... but how does the quad run once its stared?!? thats the main question! Quote
bansheesrtoys Posted January 30, 2011 Author Report Posted January 30, 2011 make sure the floats are set the same on both carbs.. and the jets in the carbs have numbers on them just make sure the 2 mains match eachother in the opposite carbs and do the same with the smaller jets... then let me know.. if you have aftermarket pipes and/ or filter box the jets need to match them... if u dont have the jets right it will never run right and u gotta get that done by a specialist or yamaha stealership..... but how does the quad run once its stared?!? thats the main question! the floats height are set right, i did it mid of last summer when i rebuilt the carbs.and i know they have numbers that why i said i put 330 mains in. All of the jets match in each carb. I do have T5's and a toomey 2-1 with k/n air filter. the main jets i put in are brand new too. why would i bring my banshee to someone to jet it? i'm pretty close and it's not that it don't run good its the choke doesn't do anything.It run great and starts one or two kicks.i didn't have this problem till i switched the bowls over to the right carbs. Quote
armyvet Posted January 30, 2011 Report Posted January 30, 2011 maybe your rich already so you dont need the choke to start it.? Quote
bansheesrtoys Posted January 30, 2011 Author Report Posted January 30, 2011 maybe your rich already so you dont need the choke to start it.? yeah but it should still idle up when i pull it. it doesn't. oh and i have a 320 jet in right now not 330. Quote
banshee55 Posted January 31, 2011 Report Posted January 31, 2011 That should fix the bogg alittle... But i guess just mess wit the airflow skrew... 2 turns out... Quote
bansheesrtoys Posted January 31, 2011 Author Report Posted January 31, 2011 what bogg? it don't bogg and i never said it did. and as far as the air screw i will try it. Quote
bansheedude55 Posted January 31, 2011 Report Posted January 31, 2011 im sure there was a little bog but now that u bumped it up to 330 itll run alitlle better. and yea try the air skrews Quote
