i have a 2006 banshee and would like for someone to show me how to change the brake pads. The pads are thin and ned changing. I have never changed them but would like to do it my slf before i pay someone to do it. I need to know what tools i need and step by step directions on what to do. might have to call me cuz im so green..please anyone.
unbolt caliper from brake stay mount for the rear caliper or unbolt em from the spindles if your working on the fronts.
remove brake ressy cap
use a C-clamp to press the piston back into the caliper
remove the two allen head bolts that are holding the brake pads, these bolts are called 'pins'.
remove the old pads, and install the new ones.
Profit
Do not remove the brake lines from the calipers
Put some anti-seize compound on the brake pins
when you press the piston back into the caliper, make sure you press it all the way in.
I don't know how much the piston will push the fluid up but I would have someone watch the reservoir to make sure you don't overflow it, brake fluid will make a real mess. I would also suggest looking for a Banshee repair manual, it pays for itself the first time you use it. They are pretty easy to do on Banshees, Meat has the steps down pat.
