I have dual 34mm Keihin on a stock motor. They stock carbs are trash and this is all I have at the moment to replace them. Does anyone know JET sizes that might work with this? I know it wont ever be really perfect since the carbs are way too big. Or should I not even waste my time and try to find something different.... I was thinking the 2 to 1 set-up but I would rather get it running decent until I get some motor work done when money allows it. Any help is appreciated!
i would suggest upgrading the motor some, like put some pipes on it to make those huge carbs work.
Yea, I am going to pick some T-5s up today and see what it does. But, the bike they came off had pipes and it just was a turd out of the hole.
\its probably too rich on the bottom. OR your trying to take off way to low in the rpm's/// its NOT a 4 stroke you gotta rev it a lil bit to get them to go.
Well.... I got the jetting right and about 2 minutes later the left piston decided it didnt want to work anymore. Now I have an excuse to put a new motor in.....
What aftermarket parts do you have on your engine?
What your elevation?
What is your temperture ranging from: day/night?
