bigblockbanshee Posted November 22, 2010 Report Posted November 22, 2010 Ok so I'm trying to recoup some money to try and get my ride done and here's what I've got left over so far. All prices are plus shipping and 3% PayPal fees, except for the boost bottles which I've already listed in another thread so I don't wanna mess up the pricing on those. I'll work with you on anything that I can. I will only ship to the Contiguous 48 United States as well. If you have any questions you can PM me on here or for faster response email me at [email protected]. Now to the parts... The rear carrier came on my '97 when I bought it although I don't know what year it is from because my frame was red and obviously this is silver, not that it would make a difference as I'm pretty sure they're all the same. As you can see this one has been tapped and had a grease fitting installed. Needs new seals and bearings too. $30 Rear Carrier One is brand new and the other came on my 'shee when I bought it. Looking for $15 for the new one and $8 for the used one. Both of these prices are SHIPPED. Boost Bottles Headlights are off of my '97. The grilles are a bit tattered, one of the glasses is cracked, one is missing an adjustment screw, harnesses are good and intact on both. Someone may be able to clean them up and use them. $15 Headlights Just another piece that came with a spare motor I got with my 'shee. Nothing at all wrong with it, just don't need it. $15 Kickstart Mechanism Same as above, came with the spare motor that I bought and didn't need it. Also comes with pressure plate bolts/screws, not pictured. $40 Clutch Basket, Flywheel, Pressure Plate These came on my '97 and like a fool I tried to modify the lower eyelet on one of them and probably ruined it. The other shock is good as far as I can tell but if not maybe someone could use the springs on another set of shocks. $15 Front Shocks/Springs This crank came out of my 'shee and as you can see one rod is severely bent and as it sits the crank cannot be used. If someone wanted to put a new rod and new bearings throughout it though it would be a perfect candidate for a fresh build. I just don't have the money to do so. $15 Crank This cover came off of the spare motor that I bought and as you can tell it has some paint worn off and has some rubbing on top of it from the kickstarter. Can be easily cleaned up and used again with a little TLC. $15 Clutch Cover with Water Pump Again, came with spare motor that I bought with my 'shee. Probably needs rebuilt unless you don't care for the shake and rattle like they do. $10 Kickstarter Once again, came with spare motor. It is completely stock, maybe someone could do something with it. $5 Stator/Timing Plate The A-Arms are a different issue. I'm only selling these IF, and only IF, I can find a nice set of standard travel extended arms to put on my '97. They have brand new caps and bushings. The caps I may end up keeping depending on what I can find on the extended arms. I had them repainted black along with my frame with PPG K36 and DCC9300 and then knocked down the shine and painted over it with satin black. As you can see they are currently installed but aren't tight and can easily be removed. If I do find another set I'll let these go for $150. Just wanted to get these out in the open and see what kind of interest I could get on them. Stock A-Arms Quote
eric b Posted November 22, 2010 Report Posted November 22, 2010 Send me paypal info on clutch parts. Consider sold. Thanks. Quote
bigblockbanshee Posted November 22, 2010 Author Report Posted November 22, 2010 [email protected] is the paypal address brother. Thanks a ton. Quote
eric b Posted November 23, 2010 Report Posted November 23, 2010 [email protected] is the paypal address brother. Thanks a ton. Cash sent. Quote
bigblockbanshee Posted November 23, 2010 Author Report Posted November 23, 2010 Thanks again. Will ship out first thing in the morning via USPS. Quote
bigblockbanshee Posted November 23, 2010 Author Report Posted November 23, 2010 Clutch and headlights sold. Come one, come all, someone needs this stuff. Quote
sheesunderme Posted November 23, 2010 Report Posted November 23, 2010 Ok so I'm trying to recoup some money to try and get my ride done and here's what I've got left over so far. All prices are plus shipping and 3% PayPal fees, except for the boost bottles which I've already listed in another thread so I don't wanna mess up the pricing on those. I'll work with you on anything that I can. I will only ship to the Contiguous 48 United States as well. If you have any questions you can PM me on here or for faster response email me at [email protected]. Now to the parts... The rear carrier came on my '97 when I bought it although I don't know what year it is from because my frame was red and obviously this is silver, not that it would make a difference as I'm pretty sure they're all the same. As you can see this one has been tapped and had a grease fitting installed. Needs new seals and bearings too. $30 Rear Carrier One is brand new and the other came on my 'shee when I bought it. Looking for $15 for the new one and $8 for the used one. Both of these prices are SHIPPED. Boost Bottles Headlights are off of my '97. The grilles are a bit tattered, one of the glasses is cracked, one is missing an adjustment screw, harnesses are good and intact on both. Someone may be able to clean them up and use them. $15 Headlights Just another piece that came with a spare motor I got with my 'shee. Nothing at all wrong with it, just don't need it. $15 Kickstart Mechanism Same as above, came with the spare motor that I bought and didn't need it. Also comes with pressure plate bolts/screws, not pictured. $40 Clutch Basket, Flywheel, Pressure Plate These came on my '97 and like a fool I tried to modify the lower eyelet on one of them and probably ruined it. The other shock is good as far as I can tell but if not maybe someone could use the springs on another set of shocks. $15 Front Shocks/Springs This crank came out of my 'shee and as you can see one rod is severely bent and as it sits the crank cannot be used. If someone wanted to put a new rod and new bearings throughout it though it would be a perfect candidate for a fresh build. I just don't have the money to do so. $15 Crank This cover came off of the spare motor that I bought and as you can tell it has some paint worn off and has some rubbing on top of it from the kickstarter. Can be easily cleaned up and used again with a little TLC. $15 Clutch Cover with Water Pump Again, came with spare motor that I bought with my 'shee. Probably needs rebuilt unless you don't care for the shake and rattle like they do. $10 Kickstarter Once again, came with spare motor. It is completely stock, maybe someone could do something with it. $5 Stator/Timing Plate The A-Arms are a different issue. I'm only selling these IF, and only IF, I can find a nice set of standard travel extended arms to put on my '97. They have brand new caps and bushings. The caps I may end up keeping depending on what I can find on the extended arms. I had them repainted black along with my frame with PPG K36 and DCC9300 and then knocked down the shine and painted over it with satin black. As you can see they are currently installed but aren't tight and can easily be removed. If I do find another set I'll let these go for $150. Just wanted to get these out in the open and see what kind of interest I could get on them. Stock A-Arms I'll take the timing plate, will pay with paypal, send info to [email protected], thanks Quote
bigblockbanshee Posted November 23, 2010 Author Report Posted November 23, 2010 Timing plate sold pending payment. Quote
bigblockbanshee Posted November 23, 2010 Author Report Posted November 23, 2010 Flywheel, clutch, headlights, and timing plate are all sold and will ship out via USPS first thing tomorrow morning. Thanks all! Quote
bigblockbanshee Posted November 23, 2010 Author Report Posted November 23, 2010 bumpity, need this stuff gone Quote
stacman450 Posted November 23, 2010 Report Posted November 23, 2010 bumpity, need this stuff gone you are a homo.... Quote
bigblockbanshee Posted November 24, 2010 Author Report Posted November 24, 2010 Bump again, don't be afraid to make me an offer. Quote
bigblockbanshee Posted November 26, 2010 Author Report Posted November 26, 2010 Will be adding more parts on Friday to try and regain some money to finish this thing... Happy Thanksgiving! Quote
t0r Posted November 26, 2010 Report Posted November 26, 2010 upper + lower a- arm + spindle for both sides for $150? Quote
bigblockbanshee Posted November 26, 2010 Author Report Posted November 26, 2010 Well I can't let go of the spindles at all really but as for the a-arms themselves I haven't found any extended a-arms yet to replace my stockers but I'll keep you in mind and as soon as I find some I'll hit you up. Quote
