i just installed a new barnett clutch on my shee it had a stock clutch that was slipping. now i have nothing at all i adjusted the the clutch and i adjusted the lever but still nothing i put everything that comes in the kit and it just seems something is missing.i have the same amount of plates as the stock clutch. i have about 1/8" gap from the pressure plate to the 1st clutch plate. can anyone help me??
Your pressure plate is out of time with the inner hub. If you look on the pressure plate, there are some arrows on it. They need to line up with the arrow on the inner hub. I think ou just need to take the pressure plate back off, rotate it one bolt on the hub and reinstall it. You should then be good.
OK THANKS THAT MAKES SENCE ILL TAKE IT DOWN THIS WEEKEND AND LET U KNOW WHAT I FIND
