Well i had to split the case on the banshee i just bought to replace the crank that had a broken rod. Anyways ive never been this far into the engine and was just wonder what the torque need to be on the bolts that hold the case together and if there is a specific tightening procedure. Any info would be great. Thanks
tighten crankcase nuts 1-8 to 3.6 ft lbs
tighten crankcase bolts 9-16 to 3.6 ft lbs
then crankcase nuts 1-8 to 7.2 ft lbs
crankcase nuts 1-8 to 18 ft lbs
crank crankcase bolts to 7.2 ft lbs
this is per the clymers manual.
