The 9 plate nmotion clutch is a little tricky to run with a lock up but it works. You have to double ball it,lol and grind a little off the pp for the lock up fingers to clear so you can pull in the clutch. Anyways the cover has a temp gauge installed and a 1/2 vent line hose aswell. everything is in pretty good shape just your normal nicks and scuffs from use. with the lock up on with this cover it is a little tight but it clears
comes with cover, no water pump, 9 plate basket and inner hub. backing plate and cushions. 550
