bansheebill Posted October 21, 2010 Report Posted October 21, 2010 Picked up this banshee for nothing almost...because it pours white smoke out of the right side pipe, thought it could be a piston ring, a crankseal or a head gasket. Just wanted some insite on what yall thought it was and how to fix Quote
STINKYDELUXE Posted October 21, 2010 Report Posted October 21, 2010 Picked up this banshee for nothing almost...because it pours white smoke out of the right side pipe, thought it could be a piston ring, a crankseal or a head gasket. Just wanted some insite on what yall thought it was and how to fix Does the smoke smell like tranny fluid? if it does more then likely it is the crank seal make sure your bearing is still good if it is my bearing blew and took out the seal. Quote
