loaded yfz450 - stroker, +2+1 elka, race ready
Minkia38
Up for sale, a beautiful tricked out 2004 YFZ450 - fully aftermarket
Clean Michigan title
Custom Graphics kit
Newer style seat with extra padding
ELKA triple rate shocks with remote reservoirs - fully adjustable race suspension. Powderocated to match frame
Wicked +2 A-arms
Stainless Steel front and rear brake lines with billet clamps
Lonestar rear extended +2/+4 axle
Lonestar Sprocket Hub
Lonestar Brake hub
Lonestar Locking axle nut
Lonestar front aluminum hubs
Maxxis Razr tires or custom ring reinforced bead lock style aluminum rims
Polished rear swing arm
oversized oil tank
billet thumb throttle cover
Bille gas tank cap
Stainless steel oil lines
Powder coated frame, engine covers, steering stem
K&N air filter
IMS ROLL DESIGN kick up foot pegs and heel guards
Full Yoshimura pipe and silencer
PEP easy pull clutch lever
new battery
Sidewinder titanium sprockets and chain
GYTR billet brake lever
GYTR billet shifter lever
High output stator alternator
GYTR ignition CDI box
Pro Taper Bars
Billet oil dipstick and timing plugs
GYTR frame guards
JRD billet front bumper
Push button start AND kick start
ENGINE:
2005 motor
Built by CDB Motorsports
oil mod
new cam chain
WR Stroker crank
CP 13.5:1 Piston
Port and Polish by BCS Performance
Web Cams 187+ 2.5 grind (modded)
YZ 9 plate clutch setup
New bearings and seals in the bottom end
Carb has NCVQ needle and zip tie air screw
$5000, the motor alone cost almost that when it was built....
