punkass1323 Posted August 16, 2010 Report Posted August 16, 2010 WHERE TO START WELL I BOUGHT THIS BANSHEE WITH MY EYES CLOSED BASICLY ITS A 97 THE GUY I BOUGHT IT FROM SAID ITS GOT ALOT OF AFTERMARKETS DONE TO IT HASS HEADERS TOOMEY PIPES BOYSEN REEDS COOL HEADS SAID ITS BORED NOT SURE TO WHAT WELL HE SAID IT JUST NEEDS A COIL GOOD GREAT THATS DONE NOW THE PROBLEM IS HE HAS THE Keihin SINGLE CARB ON IT BUT THE THROTTLE CABLE IS RIGGED BEYOND REDNECK I CANT SEEM TO FIND WHERE I CAN BUY THE RIGHT CABLE ALSO I JUST CHANGED OUT THE CLUTCH CABLE AND EVERYTHING LOOKS GREAT BUT WHEN I PULL THE LEVER IN IT DOES NOT ENGAGE THE CLUTCH I MADE SURE EVERYTHING IS TIGHT BUT STILL NO LUCK CAN ANYONE HELP ME OUT I KNOW THIS IS MOST LIKELY AN EASY FIX ON THE THROTTLE CABLE AND CLUTCH CABLE BUT I CANT FIGURE IT OUT THANKS Quote
punkass1323 Posted August 16, 2010 Author Report Posted August 16, 2010 buy a throttle cable for either a 250r or blaster. both should work without a problem. i am using a blaster cable for my single. also about the clutch. i would suggest take your cover off, and making sure the clutch is all there. not missing any steels or fibers. then take the pressure plate off and make sure the rod is in there. there should also be a ball bearing in there. take a phillips screwdriver and put it into the hole, have something squeeze the clutch lever, see if the screwdriver moves anny. thanks will do Quote
punkass1323 Posted August 16, 2010 Author Report Posted August 16, 2010 thanks will do just want to check before i buy this on ebay but will this cable work http://cgi.ebay.com/ebaymotors/Yamaha-Blaster-TORS-Elimination-Thumb-Throttle-cable-_W0QQcmdZViewItemQQitemZ200317705495QQptZMotorsQ5fATVQ5fPartsQ5fAccessories Quote
wfobasheeboy Posted August 16, 2010 Report Posted August 16, 2010 just want to check before i buy this on ebay but will this cable work http://cgi.ebay.com/ebaymotors/Yamaha-Blaster-TORS-Elimination-Thumb-Throttle-cable-_W0QQcmdZViewItemQQitemZ200317705495QQptZMotorsQ5fATVQ5fPartsQ5fAccessories First off welcome to HQ. That will work. But You should check with Jeff at F.A.S.T. He will get you what you need. Plus he is a site sponsor & good Prices. F.A.S.T. Racing Website: http://www.farmandsandtoys.com Contact: 785-364-5325 Quote
punkass1323 Posted August 16, 2010 Author Report Posted August 16, 2010 First off welcome to HQ. That will work. But You should check with Jeff at F.A.S.T. He will get you what you need. Plus he is a site sponsor & good Prices. F.A.S.T. Racing Website: http://www.farmandsandtoys.com Contact: 785-364-5325 o ok kewl again thank you now one more thing this might be the dumbest question u might read hey i gotta find out some how now do i need to mix my gas and oil if so why is there an oil resivour Quote
So Cal Suspension Posted August 16, 2010 Report Posted August 16, 2010 o ok kewl again thank you now one more thing this might be the dumbest question u might read hey i gotta find out some how now do i need to mix my gas and oil if so why is there an oil resivour Uhh, what? If you're talking about the little bottle underneath the seat, that is a coolant overflow bottle... Do not put oil in there. Yes... you need to premix the gas. Use the search function to find the 458,000 threads that have been started about oils and mix ratios. Please do not start a new thread asking what oil or ratio to use. Quote
muggzy Posted August 16, 2010 Report Posted August 16, 2010 ...now do i need to mix my gas and oil if so why is there an oil resivour If you're talking about the crank case - that's the transmission (lower end). For your gas/oil mix, make sure you use a high quality 2-cycle oil that is synthetic or synthetic blend and 4oz/gal will give you a safe, 32:1 mix. Quote
alf44 Posted August 16, 2010 Report Posted August 16, 2010 I have a slightly used throttle cable for a 2-1 and can also get you new if you like. Actually placing a Vitos order today. Always try to hit up site sponsors before Ebay. We and the site appreciate it. Quote
punkass1323 Posted August 16, 2010 Author Report Posted August 16, 2010 I have a slightly used throttle cable for a 2-1 and can also get you new if you like. Actually placing a Vitos order today. Always try to hit up site sponsors before Ebay. We and the site appreciate it. thank you all very much i know ask some crazy crap but if i dont ill never know thank you all again Quote
