Does anyones elses pingal valve tighten up pointing in the worst direction??? mine always ends up pointing towards the front of the cylinder..... banghead.gif
Its simple. Put more tape on it, and point it where you want it. No need to over tighten it.
Try wrapping it with extra teflon tape worked on mine i was having the same problem.
Yea, I agree. More tape will do it. I was having a few issues like this when I first installed mine. I recently just took it off, to clean it, and clean my tank out. I took the old tape off, put new tape on, and put it back on. More tape will solve that problem.
Thanks guys, you were all right........my problem was that i was using teflon paste... not tape. my bad. cleaned it up,used lots of tape and snugged it up right where i wanted it....
