252wheelieking Posted July 17, 2010 Report Posted July 17, 2010 Can any body give me any ideas, why coolant keep flowing out of the overflow hoses under hard acceleration? I had a friend tell me, its the signs of a blown o ring on my coolhead. It keep running my reservior bottle low & my acceleration is very weak. Quote
jasons Posted July 17, 2010 Report Posted July 17, 2010 Can any body give me any ideas, why coolant keep flowing out of the overflow hoses under hard acceleration? I had a friend tell me, its the signs of a blown o ring on my coolhead. It keep running my reservior bottle low & my acceleration is very weak. from my experiance with this issue. i had a blow oring on my dome and i was pushing coolant out the hoses as well. i would pull the head and check all your orings. Quote
ItOnlyTakes2Strokes Posted July 17, 2010 Report Posted July 17, 2010 from my experiance with this issue. i had a blow oring on my dome and i was pushing coolant out the hoses as well. i would pull the head and check all your orings. X2.... cylinder compression leaking through the head would put added pressure on the coolant system causing the overflowing... Quote
