Have any of you guys tried out dynabeads. When I'm getting it up the road my shee starts to get a vibration once the speed starts to get up there. So I was wondering if they would help. Dynabeads
From what I gather the constant acceleration/ decelleration of a quad would probably render those useless
Might help on a looong stretch though
Edited by SLORYDER
isn't there anybody with some usefull info about these things?
they are a gimmik ! just use good quality rims and tires and make sure their not bent, you could have them balanced
We've tried a simalar product in sprint car's before with little sucess. Due to the high rate of speed the tire is spinning, quick deceleration, and sliding it would end up causing worse vibrations.
Just have them balanced with regular sticky weights.
But you might want to make sure your axle is true and your wheels are not bent in anyway before you go to this extreme.
Edited by someone82
Axle is a brand new dura blue and my rims are brand new ITP bajas. I just rebuilt my shee its not like it is in my sig. It did it before the rebuild also and since its still doing it I guess its gotta be the tires.
good luck..
you have dirt tires.. i bet if you spin balance them you will notice that they wobble just a lil bit if the vibration is REALLY bad you might have some other problem.
