out of no where i lost spark while driving. i got it home checked it out. couldnt find any wiring issues... checked for spark and got nothing. then i took off the fly wheel cleaned it all out and got like 1 or 2 sparks a kick.... but wont keep sparking. any help. is my coil going bad. i checked the caps wiring and put new plugs on to check it out.
its your stator same thing happened to me a couple weeks ago, could also be the cdi, but ill put money on the stator is bad
yah i thought it was funny when i played with it it worked a little.. idk i dont want to replace it yet. any sugestions, or test i can run on a multimeter.
yah, ohm check it at the plug. red to green usually reads between 16 and 20 ohms. that's the ignition windings on the stator. red/white to green/white should be around 100 ohms. that's the puckup coil on the outside of the flywheel. make sure the gap on that is about the thickness of a sparkplug box. how are you removing the flywheel? i would shake it and listen for a magnet or 2 rollin around. now, is it sparking, and then not, or does it spark about every 2-3 kicks? that will also point where the prob is
yah, that's a sign that the stator is not giving enough juice to the cdi. the cdi is having to build minimum charge before it sparks. check the wiring between the cdi and stator, and check out the stator/flywheel. you could've melted the wires by the airbox on the exhaust. you can check the magnets in the flywheel by shaking it like a maracca, and running a screwdriver across the inside and it will jump from the center of one magnet to the other, evenly spaced. likely just a bad stator, and i've seen them ohm out ok, but not put out enough.
