First up is a awesome set of T-6 pipes with like an hour on them at most, this chrome is almost perfect with the exception of a little bit of blueing on head pipe in the normal spot, there is only like one other spot that is even noticeable. this is for the chrome pipes and the chromed stinger tubes.... no silencers with these. lookin to get $325 plus shipping... can't get much closer to new than these!
And last but not least is a pair of unused pistons, they are namura, I purchased them they were supposed to be for 1.00 over but as you can see from the 65.5mm reading they were not the right size, i put the cylinders on and turned it over a few times, then came to the realization that they were not the right size so i stuck them on the shelf to use another day, they should work fine for the correct size bore... lookin to get $50 plus shipping
The pistons are possibly ART i guess, or namura... the box of odds and ends that they came from, i was told namura, so i guess it's up to you! sorry for the confusion.
