i pulled my banshee arpart and on the top of the piston it has a G and a arrow on the top how do i tell what size it is
There should be more numbers stamped into the top. Clean it off a bit and see.
You can also use a bore gauge to measure it also.
  • Like 1
Not all pistons are stamped on the top, but most of the good name brands are, so try to clean the carbon off and see. If it is not stamped, then you can use a micrometer on the piston and/or a bore guage on the cylinder to determine what size it is.
  • 3 years later...
