ok so i got my banshee, and the otherday i let a friend on it and when he got off the float in the carb was stuck so it was dumpin gas out the over fills, got that problem fixed but now when it starts and i give it gas it boggs down at bout 1/4 throttle im guessin its a jetting problem but im not sure. so im lookin for some help. any help is great.
thanks
drake
Did u just fix the float prob or did u clean the carbs while u were in there? Did u mess with the air screws at all? I'm guessing it is that the carbs aren't synced. Hope this helps. Also what did u set the floats at?
i took the carbs apart and cleaned the carbs and the floats, im not sure what the floats where set at i just put them back the way they came out, im hopeing that my problem is something small i dont no much about 2 strokes yet but im hopeing that im just over looking something and it just needs a jet kit or something.
thanks
drake
Stay away from the jet kits. One of the site sponsors can hook u up with all the jets and parts u need. What's ur mods, elevation, temp and jets ur running now. This way we can help better to know what's going on better.
