Got it right off the front of their website
Use a 6mm wrench to unscrew this jet, and replace it with the #280 jet found in your Toomey Racing Jet Kit.
NOTE: The #270 Jet is for operation higher than 2500 feet in altitude. The 280 is the sea level setting up through 2500 feet. On particularly cold days or at very low altitudes (winter in Glamis, CA) you may need a #290 or #300. Conversly, at high alitudes, above 3000 feet you may need a 260, 250 or even less depending on how high you are and how hot it is. We haven't tested at these altitudes, so any recomendation from me would just be a guess. You would do far better to test it yourself when you are there.
