hey people i just joined the forum today and i was wondering if u guys could help me out
i have an 03 banshee and i recently installed fmf fatties and turbine core 2s.
i took off the air box and installed k&n pods.
My elevation is no more than 300 feet above sea level.
the stock mains on my carbs right now are 200 and the pilots are 25.
does anyone know where should i start for the jetting?
or does anyone have the same mods on their banshee and know what jets your running?
Thanks guys
Edited by bringthepain
Thanks guys
Well most aftermarket pipes need 27.5 or even 30 pilots, for mains you should start rich and work you way down. Start with 330 mains and see how it runs if it sputters before the powerband go down one and see how it runs then do a plug chop, o ya what is your temp
ya you can get away with the stock pilots, mine always started and ran good but i recently switched to 27.5 with t5s rmatv sells them
ok thanks man. usually its around 75-80 degrees fahrenheit
if it is in that usuall heat range, try out 290 first, but go higher if it's colder. the fatties often call for 27.5 pilot, but not always.
