i started my banshee after a week of sitting and it is making a ratting noise.sounds like its comming from the crank.i cant recall it making this kind of noise before.would appreciate any opinions.
I would start by ruling out the obvious by just holding your hand over just about everything on the quad especially the kickstarter those always wear and start to rattle, does it sound like a knock or rattle?
well it could be a number of things But I had the same thing last summer and it turned out to be that the kick start idler gear had lost a tooth. I wish I would have pushed it back instead of riding Back, It ended up taking out the crank seal. It wouldn't hurt to have a peek.
how do i tell if the water pump is bad?
Take it out and look. :unsure:
Your going to hope for an answer that doesn't require you to split the cases.....But if the noise is "IN" the motor...That's where you need to look. You can only see so much thru the intake and exhaust openings.....Or you could try sawdust in the oil, run a nice rearend fluid in the trans and ride with an Ipod turned up. :rotflmao: I'm sure the sound will go away if you rev it up and beat on it for a while. :lol: Start with draining the oil and checking for metal shavings.....
