Tons of stuff, I have a bunch up on ebay too:
http://stores.ebay.com/Motor-City-ATV?refid=store
Ray's current ebay auctions
Frame components
J Frame $150.00 (titled add $100), A-arm frame, $225 (titled add $100),
Steering stem $30.00
A-arms / J-arms with brakes, hubs, spindles, and tie rods $250.00
Swingarm $30.00
Axle $100.00
Bearing carrier $60.00
Footpegs $10.00
Nerf Bars / Metal Heel guards $50.00, add $75 for plastic heel guard pieces
Rear Hubs $35.00
Rear Sprocket & Hub $15.00
Rear Brake disc & Hub $15.00
Dogbone $10.00
Rear Grab Bar $15.00
Front Bumper Pushbar $50.00
Shifter $10.00
Skid Plate $20
Running Engine $1000.00
Rubber intake boots/Boost $30.00
Reeds and cages $20.00
Carbs and cable $100.00
Airbox (or air filter) $50.00 - $100.00
Kickstarter $50.00
Gas Tank $25.00, $15 for one with bad fenders mounts
Pipes $35.00 stock - $300.00 chrome aftermarket
motor parts:
cylinders $300
crank $150
shift drum, rods, forks $15
gears/tranny $100
cases $100-$200
clutch cover with impeller $40, full mirror polished: $125
plastic stator cover $ 15
stator & timing plate $80-$100
internal bolts $25
head $15-$35
flywheel $75-$100
Plastic
Front & rear Fenders $100 - $300
Radiator Plastic $35
Gas Tank Plastic $35
Seat w/ latch $40-$100
Front Fender brackets $15
Electrical
CDI Box $60.00
Wiring harness / Loom $30.00 - $50.00
Coil $20.00
Headlights $80.00
on/off switch $25.00
Key w/ plastic housing $35.00
Taillight $20.00
Misc
Rear brake setup $100.00
Bolt set $25.00
Rear Shock $75.00
Front shocks $80.00
Front tires & rims $50 - 200.00 varies
Rear tires and rims $50 – 200.00 varies
Handlebars & grips $10.00, aftermarket with pad $20
Clutch lever / perch $10.00 - $20.00
Thumb Throttle assembly $25.00
Radiator & Reservoir & lines$25.00
Radiator only- $20
Front brake lines $10.00
Front brake lever/rezzy $15.00
Motor Mounts $10.00
I've been looking for 25 sets of stock pipes forever now, and I finally found them! Just kidding, let us know if those ever get sold, I know you will probably only make a little bit off of them considering shipping and what not. How long have you been collecting banshees for? And more importantly, how do you keep them all safe? :ph34r:
yeah, i have about 75 sets now, I dont think they will ever sell, so they will probably end up in scrapyard soon......
how much for a stock carb set up complete with airbox and throttle cable?
stock carbs and throttle cable are $90
airbox without filter is $50
airbox with stock filter is $70
airbox with K&N is $80
airbox with lid, pro design adapter, k&N, and snorkel is $90
wow you really have a good stuff in your ebay store but seriously you need to work with the shipping prices!!! actually I'm interested in this item 370316505204 but the shipping prices killing me. Just my opinion GLWYS!!
Opinions are good!
I lower the cost of the item by raising the shipping a little bit, this offsets the ebay lisitng and final value fees and the paypal fees, without adding to the cost of the item. I tack it into the shipping instead. This also includes the boxes, tape, labels, filler materials, and time it takes to package the item, and ship it out.
Hope this makes sense!
Ray
Motor City ATV
Ive questioned the shipping a few times also. Some parts prices are fair here, but well.....nevermind dont want too start anything. Just be aware. Good luck.
