I have a graydon proline 2 into one intake with a k+n filter (the filter could use replacing) for sale runs great need to sell because I am building a cub. Will trade for 30mm or 34mm pj's or sell for $175.00 shipped.
I'm looking for one....but that one looks odd. What's bolted/clamped to it in front of the carb? Got any pics with it off the bike and cleaned up?
Either the air cleaner or the intake that bolts to the 2 into one. I have not taken it off the bike yet but if you are interested i can pull it off tommorow and get you some cleaned up pictures.
Looks like it was modded. The standard Graydon doesn't need an intake bolted to it. It just has a rubber hose with a clamp to the 2 into 1 and a clamp on the carb. I can't see what you have going on there with the pipes in the way. But judging from the extra long bolts and nuts, I'd say it looks a little rigged. Id like to see some better pics if you could....
I dont know about it being a little rigged. I bought it off here and have ran it for a couple months and it has worked alright, I just want to go to something that is going to work on a cub. I can get you some better pictures if you are genuinely interested. But more specifically what do you want?
Asked for close-up pics of it already. :huh: Cleaned up and off the bike (So your pipes aren't covering the stuff that I have a question with)
I means Bye.
whoops i never actually looked at this one.
maybe graydon changed the design? for whatever reason?
i ran one of these with a 39mm pwk for about 2-3 years in MX it worked great. but it just had the hose for mounting the carb..
this is what i know. I bought it off a member here, he said it was a graydon proline, I traded for it and now i want to go back to duels for a bigger motor. I had to do a bunch of jetting and needle changes to get it correct and have done so, I will throw in the "stock" needle that came with it as well as the one i bought, ill throw in a brand new throttle cable and thumb throttle as well as a k+n that is on it with a outerwear. for 150 shipped.
Edited by 01banch
