after aobut 2 months of not riding my shee ,it started with about 20 kicks,it was smoking as usual but then i took it around the track a few times and it was back fireing like hell so i pulled of the track and gave it just enough gas to keep it at a high idol then it just died and didnt start back up,im gonna take a guess that it was gummed up but im not entirely sure, and help would be great thanks
i'm gonna guess it still had some old premix in there? well, start by cleaning out the casrbs and drain the tank/clean if need-be. get some fresh premix in there and new plugs and see how it runs....look for airleaks, too
Also with low compression it will be hard to start. So if you have one on hand you might want to check them while you have the plugs out.
i dont think its compression cuzz i just rebuilt aobut 2 months ago, and now i found a new problem the right cylinder is smokin as usual but the left isnt smokin at all and its pumping out ice cold air and the left pipe is cold while the right one is hot and smoking
