SubarusAreMyThing Posted November 29, 2009 Report Posted November 29, 2009 Need some insite on my head lights. for a 2003 banshee. They dont come on in either high or low positions. I checked the bulbs, they are both fine and both light up when supplied by battery power. I tried to trace a few wires, but they quickly ran under the gastank and behind the radiator, and i dont have the time to pull those off right now as i plan on going riding later today and tomorrow. I searched for a fuse box, and couldnt find one.' Any tips or maybe common problems to check when i have the time? I absolutly hate chassing down wires with a multimetere. But if i have too, guess i will. Quote
Snopczynski Posted November 29, 2009 Report Posted November 29, 2009 You need to check for voltage where it comes out of the stator connector with a meter or a test light. Check it with the bike idling, do not rev it up. Quote
SubarusAreMyThing Posted November 29, 2009 Author Report Posted November 29, 2009 You need to check for voltage where it comes out of the stator connector with a meter or a test light. Check it with the bike idling, do not rev it up. what voltage do these run? I can probably do that while im waiting for it to warm up before we hit the trails today. Quote
AKheathen Posted November 30, 2009 Report Posted November 30, 2009 10-16 or 17v a/c yellow and black wires with the bullet connectors Quote
SubarusAreMyThing Posted November 30, 2009 Author Report Posted November 30, 2009 10-16 or 17v a/c yellow and black wires with the bullet connectors hey thanks for the reply! but i already got it figured out and they work now. i think it was just a bad connection because all i did was unplug those yellow and black wires and plug em back in. and they worked lmao. forgo to post on here i sovled the problem, but thanks for the reply! much appreciated Quote
