Whats crackin fellow HQ members!
I just put a Noss cool head and a TORS kit on my 06 shee. I did everything perfect, and the bike runs and rides awesome. My concern is, the exhaust coming from the left pipe seems to be more poppy and more flow than the right side. This problem is definitely worse when the bike is cold.
Any suggestions? are my carbs just not synced 100% perfect or what?
THANKS -Zach B.
yah, it's probably just a syncing issue, which you can set better by adjusting the airscrews to make it fire better/smoother, and adjusting the idle screws to even out the pressures, then resync the cables. however, you can also have an airleak, so definately check that....
