1998BansheeHD Posted November 21, 2009 Report Share Posted November 21, 2009 (edited) I am switching back to the 2 stock carbs over the single 33.. My mods are in my sig.. What would a good mid to top pipe. Also will my single outlet pingle feed enough fuel to the carbs? Edited November 21, 2009 by 1998BansheeHD Quote Link to comment Share on other sites More sharing options...
TwistedSheeRida Posted November 21, 2009 Report Share Posted November 21, 2009 well im not exactly sure what your asking besides the pingle valve. and yes that will work fine. if you want to know what to jet the carbs for were gonna need to know your elevation and temp. a good mid to top pipe T5, CPI inframe, Shearer inframe. Quote Link to comment Share on other sites More sharing options...
1998BansheeHD Posted November 21, 2009 Author Report Share Posted November 21, 2009 well im not exactly sure what your asking besides the pingle valve. and yes that will work fine. if you want to know what to jet the carbs for were gonna need to know your elevation and temp. a good mid to top pipe T5, CPI inframe, Shearer inframe. My elevation is 545 ft and the temp is between 30 50 degrees. Quote Link to comment Share on other sites More sharing options...
1998BansheeHD Posted November 21, 2009 Author Report Share Posted November 21, 2009 My elevation is 545 ft and the temp is between 30 50 degrees. also i forgot no airbox but foam filter with outerwear wear Quote Link to comment Share on other sites More sharing options...
