smokin350 Posted November 14, 2009 Report Posted November 14, 2009 ok heres the deal i'm building another banshee and i'm using the front lonestar hubs off my other banshee and when i took off the center caps i noticed the outer seal was mangled on both sides i guess i must of forgot to put the washers on before the main hub nut so it had some play side to side and must of eat the seal!!! where can i purchase new seals for this kind of hub or does it take the stock ones, im just not sure they kinda of look smaller but not sure cuase i havent had stock hubs in 5 years... thanks guys for any help i'll post some pics when i get home from work. Quote
someone82 Posted November 15, 2009 Report Posted November 15, 2009 ok heres the deal i'm building another banshee and i'm using the front lonestar hubs off my other banshee and when i took off the center caps i noticed the outer seal was mangled on both sides i guess i must of forgot to put the washers on before the main hub nut so it had some play side to side and must of eat the seal!!! where can i purchase new seals for this kind of hub or does it take the stock ones, im just not sure they kinda of look smaller but not sure cuase i havent had stock hubs in 5 years... thanks guys for any help i'll post some pics when i get home from work. is the seal on the opposite side hub still in good condition? If so you can probably read the part number off of it and get a replacement from you local auto-parts store. Or just contact lone star at www.lsracing.com Quote
