romelo1680 Posted November 13, 2009 Report Posted November 13, 2009 i have a 4mm vito short rod new it was bolted in a case that i was going to build. for a drag motor, i had this crank for a couple of years 300.00 i can sen pic Quote
dekker Posted November 14, 2009 Report Posted November 14, 2009 i have a 4mm vito short rod new it was bolted in a case that i was going to build. for a drag motor, i had this crank for a couple of years 300.00 i can sen pic Anyone know if you can run this crank without a spacer if you have the head cut? Quote
banshee332 Posted November 14, 2009 Report Posted November 14, 2009 Anyone know if you can run this crank without a spacer if you have the head cut? You can but I like the 115 rods this one has the 110 rods I think still a good crank though Quote
NOS_350x Posted November 15, 2009 Report Posted November 15, 2009 If you run regular pistons, have the head cut, you dont need a spacer, If you dont get the head cut you need the spacer. Quote
