went riding again today and when i went through a stream alittle deeper then knee high my quad ran like shit for a few mins i probable sucked in water right the snorkle has been removed and holes driolled in the airbox should i put a snorkel on it and if i did should i rejet its all stock but has 240 mains and runs strong i dont want to blow it upthis is the funnest quad i have ever owned
The only way to know if you need to rejet is to check the plugs. If your going to go through water that deep you need to hit it fast and skim across it, just shift your weight to the rear of the bike.
