dirtydownunder Posted November 5, 2009 Report Posted November 5, 2009 (edited) hey guys, im just about to buy some carbs and i wanted to confirm im getting the right ones. the 30mm oko's im looking at have the model number of 3020, (they have the see though bowl, do these bowls leak or warp ?) heres the ebay listing. http://cgi.ebay.com.au/CARBURETOR-PERFORMANCE-for-Quads-Motorcycles-Buggies_W0QQitemZ120485591407QQcmdZViewItemQQptZAU_Motorcycle_Parts_Accessories?hash=item1c0d80396f#ht_1098wt_1165 and where should i get the cables for these things ?. thanx andrew. Edited November 5, 2009 by dirtydownunder Quote
grandnational Posted November 5, 2009 Report Posted November 5, 2009 hey guys, im just about to buy some carbs and i wanted to confirm im getting the right ones. the 30mm oko's im looking at have the model number of 3020, (they have the see though bowl, do these bowls leak or warp ?) heres the ebay listing. http://cgi.ebay.com.au/CARBURETOR-PERFORMANCE-for-Quads-Motorcycles-Buggies_W0QQitemZ120485591407QQcmdZViewItemQQptZAU_Motorcycle_Parts_Accessories?hash=item1c0d80396f#ht_1098wt_1165 and where should i get the cables for these things ?. thanx andrew. dang never seen those before they are like lectrons.. shouldn't have a problem with them.. Quote
scottzimmerman Posted November 5, 2009 Report Posted November 5, 2009 i like them there carbs lol Quote
Drewski Posted November 5, 2009 Report Posted November 5, 2009 hey dude if you go to carbpartswarehouse you will see that they will give you cables with them. they also jet them to your mods and eleation, and give you a smaller and larger set of jets with them. Quote
dirtydownunder Posted November 5, 2009 Author Report Posted November 5, 2009 yeh i went there first, and none of the links works, and i couldnt find any helpfull info. so i tried there ebay store which didnt come up. so i kept searching till i found these. ill have to ask hjr what jets to get any way. Quote
Drewski Posted November 6, 2009 Report Posted November 6, 2009 just give them a call, and like I said they know their shit so just tell them your mods and they will jett it real close Quote
dajogejr Posted November 6, 2009 Report Posted November 6, 2009 I've got a little 21mm OKO on my 50cc pit bike. They're just like Keihins. I've never seen clear bowls like that except on Lectrons...I gotta admit, that's pretty cool. Quote
dirtydownunder Posted November 6, 2009 Author Report Posted November 6, 2009 ah k, yeh ill give them a call and see whats up, drewski. the clear bowls are cool but they will probably go to shit over time . do the oko 30's need spacers to clear the clutch arm ? Quote
dajogejr Posted November 6, 2009 Report Posted November 6, 2009 Eventually, in Lectrons anyways, the bowls get cloudy, but they're not as transparent as these are in the first place, they're like a frosted clear. Enough to see the fuel level, but nothing like these... You may have to bend the clutch arm down just a hair or take a grinder to the bottom of one of the float bowls. Reed Spacers are cheap, just get the extra gaskets needed and use blue loctite on the bolts to tighten them down. Quote
dirtydownunder Posted November 7, 2009 Author Report Posted November 7, 2009 thanx daj, can you get manifold's that are spaced out a bit or are spacer's the only way im going to move them out. im going to go the CPW route and get the whole kit. Quote
dajogejr Posted November 7, 2009 Report Posted November 7, 2009 Several manufacturers make billet intakes with the crossover tube built into them. They tend to space them out a bit more...might want to try that. Cleaner look, too! Quote
dirtydownunder Posted November 7, 2009 Author Report Posted November 7, 2009 you da man Daj, you da man ! Quote
