chitt21 Posted November 2, 2009 Report Posted November 2, 2009 What are the advantages to removing the airbox and just running pod air filters? and is it really worth it? Quote
92 Z71 Posted November 2, 2009 Report Posted November 2, 2009 Lot better air flow. If you ride in wet areas keep the airbox. Quote
chitt21 Posted November 2, 2009 Author Report Posted November 2, 2009 Lot better air flow. If you ride in wet areas keep the airbox. Alright thanks alot Quote
WantABanshee Posted November 2, 2009 Report Posted November 2, 2009 I'll trade you a brand new Toomey 2 into 1 air filter for your stock airbox and lid! Quote
chitt21 Posted November 3, 2009 Author Report Posted November 3, 2009 I'll trade you a brand new Toomey 2 into 1 air filter for your stock airbox and lid! I would man but I think after hearing its better to have it when you run in wet conditions, that I'm going to keep it on. Quote
bansheesandrider Posted November 3, 2009 Report Posted November 3, 2009 I would man but I think after hearing its better to have it when you run in wet conditions, that I'm going to keep it on. The stock airbox is better for wet conditions but the stock air box is bad for not getting the filter to seal to it properly because the lid is what holds the filter in place and it may not locate it in properly when you put it on. The solution for this is the Pro Design Pro Flow adapter or one of the copycats of this product. Install it ,clamp the filter to it, modify the lid per the instructions and your set. Then when it is dry out you can remove the lid for more power, K&N or Outerwears also makes a cover for the airbox that replaces the lid and it is supposed to be waterproof so the filter is protected from splashes-if you are crossing creeks or ponds and the water gets over the airbox you will still drowned out, but you would anyway. If your riding has only shallow water crossings, I would use the airbox with no lid , The Pro Design adapter, the Outerwears lid replacement and a GOOD FILTER for your type of riding conditions and you should be set, with decent power. Quote
chitt21 Posted November 4, 2009 Author Report Posted November 4, 2009 The stock airbox is better for wet conditions but the stock air box is bad for not getting the filter to seal to it properly because the lid is what holds the filter in place and it may not locate it in properly when you put it on. The solution for this is the Pro Design Pro Flow adapter or one of the copycats of this product. Install it ,clamp the filter to it, modify the lid per the instructions and your set. Then when it is dry out you can remove the lid for more power, K&N or Outerwears also makes a cover for the airbox that replaces the lid and it is supposed to be waterproof so the filter is protected from splashes-if you are crossing creeks or ponds and the water gets over the airbox you will still drowned out, but you would anyway. If your riding has only shallow water crossings, I would use the airbox with no lid , The Pro Design adapter, the Outerwears lid replacement and a GOOD FILTER for your type of riding conditions and you should be set, with decent power. Thanks for all the help Quote
