crustydemon Posted October 29, 2009 Report Posted October 29, 2009 My mods are in sig, I have CGL needles on the middle position right now, 48 pilots, and 165 mains. I know Im really fat on the mains but Im not worried about that yet, Im 1 1/2 turns out on the air screws just for starters,carbs are in sync.Most people say run a CEL on the middle position but It seems like Im rich already, I dont know but it smokes quite a bit (32:1 Techniplate).Starts first kick every time with no choke @ 45-50 degrees and idles great. Runs like shit. Real doggy from 1/4-3/4 then trys to kick in a bit then eats its own ass after that(mains).I think a CGL on the 5th position is the same as a CEL on the middle but Im not sure and that would just richen it up anyway. What should I try or look for to get the pilot circuit set and how do you know when to move to a different pilot jet?Where should I safely start on the mains? I have them all from 145-165. About 1400 ft and 50 degrees. Pods on it right now but might go back to open airbox. Quote
AKheathen Posted October 29, 2009 Report Posted October 29, 2009 get your mains set first. sounds like you are a couple sizes rich...... once it's goin good @ wot operating temp, do your plug chops. next, mess with the needles to get your 1/4 ti 3/4 set right. then, you do your pilots. @ 50 degrees, you need the choke, or you are too rich. again, you are making all the adjustments @ operating temp Quote
crustydemon Posted October 29, 2009 Author Report Posted October 29, 2009 get your mains set first. sounds like you are a couple sizes rich...... once it's goin good @ wot operating temp, do your plug chops. next, mess with the needles to get your 1/4 ti 3/4 set right. then, you do your pilots. @ 50 degrees, you need the choke, or you are too rich. again, you are making all the adjustments @ operating temp Right on, if the rain stops I'll go out and get muddy. Quote
