how can you tell if you have 115 rods or 110, the numbers on the side of my hot rods, rod) are ck 158
any help would be appreciated!
You can either measure the center to center length of the big and small ends of the rods or measure from the piston pin hole to the top edge of the piston. On the long rod the pin will be 5mm higher than stock.
ck158=hotrods 115mm longrod......i thaught about making a shortrod for more piston options, but longrods are more stable
thanks a miilion for answering that question! that saved me a bunch of time!
