Hi. Can anybody help?
I have bought my 1st banshee and i love it! BUT, i have just had the outer crank bearing and seals done and it has all been put back together. It ran fine but i havent had chance to take it out yet. I ran it 2day and took it up the street and back. The engine was warm and was running great so i gave it some beans on the return trip and it lost power, made a horrific knocking sound so i killed it and pushed it back. it will kick 1st time still but the knocking is really bad and i think its coming from the left cylinder? Also i think water was coming out of the exhaust but didnt run it for long enough to have a proper look. Im gonna be gutted if ive done the crank or worse and hope its just the piston as ive spent alot these past few weeks. Does anybody have a clue what ive done? Thanks
  • Like 1
Who did the rebuild for you?I had a bad knock on the left side one time and it turned out that the flywheel was loose. As forb the collant get a new head gasket and make sure everything is clean and the head is flat .
