trademark Posted October 7, 2009 Report Posted October 7, 2009 big bore stroker kit by falicon 101mm cp piston kit new 13:1 225.00 shipped cosmic gaskets new 45.00 shipped billet stroker crank maybe 3 hours run time 74.8mm stroke 10mil 750.00 shipped 101mm o ringed cylinder could use a replating 3hours run time 450.00 shipped ======================================================================= piston cp new, rebuild able billet crank 3 hours run time with knife rod ,cylinder o ringed needs replating and all gaskets needed the whole kit 1200.00+shipping this kit is 2400.00 from falicon ================================================================================================ web cam billet with adjustable timing gear custom grind drag racing tower and all 250.00 shipped grind # 242/812 valve lash .006 .009 valve lift 0.415 0.357 duration 284deg. 294 deg. duration@ 0.050 261 deg. 258deg. lobe center 110deg 104 deg power to get you gone!! ported and epoxied head by cooper performance with the works to go fast 650.00 shipped manual timing chain tension er 25.00 shipped 45mm pe5 needle lectron set-up for alky with cable 350.00 shipped moose racing thumb throttle black in color 80.00 shipped cases trenched for the big stroke 380.00 shipped 12mm apr studs 50.00 shipped hinson billet clutch basket w/stock inter and out hubs with clutches 250.00 shipped polished stator cover with stator and polished clutch cover 160.00 shipped ds 650 intake and k&n filter 60.00 shipped right side outer case with water pump and cover 100.00 shipped new RIS design billet bar clamp new just opened package never mounted 40.00 shipped mod quad rear brake lever black 60.00 shipped front drag skinnys with wheels 125.00 shipped====================================================pending RIS billet pegs 80.00 shipped jj&a drag axle with all hubs 450.00 shipped rear drag tires with wheels 20 ..10..8 200.00 shipped pro wides 2 s on wheels 170.00 shipped solid rear strut adjustable 11 eye to eye up to 13 eye to eye looks just like a shaw shock 80.00shipped[/si my name is jason and you can call me at 229-869-9821 paypal is [email protected] Quote
