I have the complete Toomey package with their T5's, 2:1 High Flow Filter System, and outerwear. The left stinger tube touches my outerwear and has melted it. It's also right up against my throttle cable as it comes out of the carb cap (TORS removed). I remember when I installed that side, it didn’t feel right. I had a hard time getting the stinger tube into the pipe. Can someone check their Toomey's and see if it's that close to their carb cap? Could I have a bad bend on the pipe or stinger tube? When I unbolt the silencers, it is definitely in a bind and I have to force it onto the bolt on the rear by twisting it.
So I just verified it's the stinger tube. I had an older one and with it, everything lines up like it should. Now I've got a thin spot on my pipe from it rubbing against the head! I'm calling Toomey on Tuesday. The stinger tube isn’t bent right compared to the old one I have. :angry:
