<!--quoteo(post=1045663:date=Aug 23 2009, 08:59 PM:name=AKheathen)--><div class='quotetop'>QUOTE (AKheathen @ Aug 23 2009, 08:59 PM) <a href="index.php?act=findpost&pid=1045663"><{POST_SNAPBACK}></a></div><div class='quotemain'><!--quotec-->did you get the pro reeds, or power reeds?<!--QuoteEnd--></div><!--QuoteEEnd-->
Pro reeds the ones with the carbon fiber top petal
those will be about perfect for the pipes. you will definately notice a smoother power transition and stronger mid-low. you may have to drop a size from pulling more air, or may not. just check after you install them. what jetting did you end up with on that setup? just curious, because i'm running pcp's, +5, 20cc's, boysen dual stage on 40:1 95oct. 350 mains, back to stock needle in middle, and27.5. asl 60*f
Well I havent done a chop yet but i have 320 s and 25 s and the clip is 1 notch lean from stock sea level 90 deg and I think I need to go down on the mains cause I get a lil studder once she gets up to operating temp. ? for you. Do you have to run more fuel for higher comp. I have noticed that most guys have larger mains with higer comp.
Edited by robert0762
