Whitbread Posted August 21, 2009 Report Posted August 21, 2009 (edited) I'm helping a friend convert a 39 pwk to be pump friendly for an extremely goofy application. Been searching around and haven't been able to find a "list" of what exactly needs to be modified/changed. Is it just the needle and seat? Best place to get the parts? 2-3psi good for fuel pressure? Thanks everyone! Edited August 21, 2009 by Whitbread Quote
Whitbread Posted August 21, 2009 Author Report Posted August 21, 2009 (edited) Electric with bypass style regulator. Edited August 21, 2009 by Whitbread Quote
Snopczynski Posted August 21, 2009 Report Posted August 21, 2009 I dont know what the needle seats are set at, but hook it up with the bowl off. Hold the floats up so the seat is closed, and see if it leaks at 2 psi. Quote
Whitbread Posted August 21, 2009 Author Report Posted August 21, 2009 I dont know what the needle seats are set at, but hook it up with the bowl off. Hold the floats up so the seat is closed, and see if it leaks at 2 psi.Will do. If it holds, we're good to go? Quote
