Hey got a 98 shee with FMF pipes and silencer, No air box, no TORS. I ride mainly tight trails. It is bogging out on me in 1-2 gear it idles good but tacks a couple twist og the throttle to clean it out. My jets are 290 elevation is 1230ft. My question is can I go down on jets to 250-270 or ? to get it not to bog down?
do a plug chop to get your mains right, then start with the needles in the middle and the airscrews @ 1.5 turns out. sync your carbs, also.
Umm where is the Bog at in the RPM? just saying it bogs is a big area to play with...Does it bog off idle...mid range...Top end? What pilots are you running? Did you resync the carbs?
