parting out my whole banshee,.. for real. I never ride it, and I want a bike. so here we go.
--98 frame yellow ppg hd paint $150+shp
--g force axle +4 $85+shp
--rear hubs yellow $20+shp
--rear carrier yellow $20+shp good bearings
Ill inc srocket hub w match paint
--rear wheels blk hipers/mx6 $350+shp 80-85% tread
--34mm mikuni tm flatslides $150+shp
--front wheels douglas flipped $65+shp
--+3+1 a arms w lines n ties $375+shp
--elka piggy rez shocks $500+shp
--rear brakes (complete) $50+shp
--ac pro peg nerfs $50+shp
--rocket pipes $300 +shp
--pods for carbs $25+shp
-- negative 2" swingarm blk $150+shp
--boyeseen dual stage carbon fiber reeds on stock cages $35 + shp
--renthal bars $10 +shp
-- nacs billet bar clamp $10+ shp
-- asv clutch lever $ 45+ shp
-- front brake master cyl/lever $15+ shp
--front rotors, brakes $55+shp w a arms $30.
-- Passion 12 port RZ cylinders (for 4mm)
they are 65.5 bore, new pistons. they bore is new. they have about 20 minutes run in on them. the dick that did the bore didnt clearance the pv`s and the piston and rings rubbed it. they need new rings and hone. pistons are still good. the worst cylinder holds 160psi. the stroke clearanced and milled head comes with. (cyls, pistons, head) very rare and expensive combo $600+shp run with vp110/93 @ 50/50
--Full Banshee setup RZ harness with matching rz 200w stator, servo all the jazz $150+shp
--lightened flywheel $65+shp
--4mm bottom end excluding above but with side covers, kick, shift, 4mm crank, billet basket, hd springs n plates $500+shp
Or motor whole w harness for $1200.
Misc brackets n crap, ask or throw offers. tank radiator plastic ect dont sell for much and will prob sell really cheap or go in trash.
Anything left over by Sat 15th will be listed on eGay. Postal Money orders get 10% off. I have paypal.
Please pm me for contact information or any questions or both.
I will sell the bike whole as is for $3500 or trade for bike year 01+ and 750cc + gsxr, r1, 929.
(mirror effect on picture)
(because this is hot)
  • Replies 39
  • Created
  • Last Reply
Top Posters In This Topic
Could i see a pic of the problem with the cylinders you are talking about???
Fastrthnu, your inbox is full man. Trying to send you a PM.
cleared it up bro, sorry bout that!
No worries, i PM'd you back and i will let you know ok......
mmmmmmmmmmmWWAAAAAAAAAAAAAA!/1!!!!!1!!!!
you're too early :confused: :banghead: :banghead: :banghead: :verymad: :shoothead:
ON THE SECOND TO LAST PIC THE CHAIN IS ON THE OPOSITE SIDE OF THE BANSHEE. WHY IS THAT?
below the picture it says ,"mirror effect on the picture". :thumbsup:
Dibs on rockets. :thumbsup:
