ok i just rebult my bike a few days ago and i was riding it the other day and at the top of 5th and 6th gear it was makeing a weird crackaling noise and now it wont fire on the left side, but befor it stoped working it was like spiting and spotering likeit was flooded, i dont think i blew it up its just running fucked up. oh and then i put new plugs in it and it started up and ran on both sides for about a couple of minutes then i hit the gas and it bogged down and the left side styoped fireing. i have no idea whats going on with it i need some help guys. thanks
Derick
swap the plug wires and see if it changes sides. then, clean your carbs out real good, one at a time. check your reeds while your in there. sounds like a broken reed, plugged jet or plug cap.
thanks guys i figured it out i used a shit ton of assembly lube when i put the jugs back on and it just fucked with the plgs the both stoped working so i oput new ones in and it runs awsome now no problems.
Derick
