anyone ever try putting blaster carbs on a banshee? i believe blaster carbs are 28mm. instead of punching out the stock banshee carbs to 27mm to 27.5mm, i would think it would be better to put on some 28mm blaster carbs and maybe even bore them out 1mm or so for a little more top end hp, if the person wanted. i would also think it would be cheaper, especially for those that can bore out their own carbs. so, anyone try blaster carbs and if so, how did it work out? any input appreciated.
oh, i was reading over on this blaster forums site, that the stock blaster carb was a 28mm. if its the same 26mm as the stock carb, then there is no sense in changing them over. thanks guys.
